Lot's of talk about what OHV motor will produce the most, better yet, since HP is over rated as MDG claims which of the two or any other OHV 6.5(claimed hp)motor can produce the most torque. Further more, I know big valve heads, stroker cranks, and alcohol carbs/ignition upgrades can be done to both , but can the same mods be made to these two engine as far as serious internal engine work; ala extending the deck(1')or runing a 4.500" rod, or boreing the sleeve to accept a larger piston(.140')?
IMOthe Animal is by far the better of the two, what do you guys think?
