Anyone know more about this twin engine bike?
race
Are those 820s? What frame / bike did it start out as? Interesting fork design.
Any pics of the other side? Would love to see how they handled the power train.
( Pic is from the 'Girls and Mini Bikes' thread #575 on p. 29 ).
race
Anyone have pics of how they did the drive train?
I like how they mounted the engines fore and aft as opposed to the side by side Double Trouble bike ... which made for a rather wide mid section. You probably came off a little bow-legged after riding it. :)
I have seen this set up before and they had the WB with 3/4" cranks in them versus the step crank. The 3/4" had the full 3/16" keyway and they used the double 12 tooth sprocket on both engines. Single chain going to the rear sprocket and the inner set of teeth connecting the two clutch drums. Lose one engine you still have drive to the rear sprocket. Just have to make sure both bushing are well lubed just incase this happens since under normal conditions the clutch drum only spins on the sleeve of the clutch at idle, once moving the shoes are locked to the drum and the clutch turns as one piece of steel and the bushing is non-functional which is why a needle bearing is not used because of cost and they cannot take heat above 250 degrees F. The crankshaft gets hotter than 250F.
