In an previous post I attached a pic of an Arctic Cat engine still in the sled. Well, it is still in the sled. Started pulling it out today. The attached picture shows how wide the engine is. The only answer is to narrow it by cutting down the out-put shaft and mounting a sprocket that drives a jack shaft which has a clutch on it. The rope start/ignition side also sticks out like a huge wart. The rope starter could be located on the jack shaft which takes some of the width off. But to do it right the entire ignition and alternator needs to be thrown away and an HTD belt [toothed belt] used to drive a two cylinder Wico or FM magneto. I have a Wico that would work, they are pretty common and easy to come by. Another plan, that would include carrying a little battery, is to provide points, condenser and coil. With those modifications the engine would easily fit in a somewhat stretched minibike frame. But for now I am just trying to get the engine on the shelf.
The engine is a 70mm bore X 65mm stroke by Suzuki. Displaces 500 cc. It runs good so I think it is worth the effort to get it out an saved back for when I have more time.
