So I purchased an ARC flywheel and timing key for our Baja MB200 LYOY motor and cannot get it to install. The problem I am having is with the light coils that are inside the flywheel. My ARC doesn't seem to fit over them. I wanted to see if anyone of you have had this issue and found a fix short of just removing the coil. I would like to keep use of the headlight.
Thanks!
Thanks!
