arctic cat cables
No, no, no.... Jeff Mihalko is your only reliable source for these. They are custom made to the correct length for the 10" bike. Only downside is that he uses brass barrels on the lever ends that are a tiny bit too narrow compared to the originals. You just need to gently squeeze. your lever halves together to compensate. The other downside is the originals were silver, not brass, but these are the closest to correct and high quality cables you're going to find. Do not buy gray cables. Jeff is at Minibike@atlanticbb.net
ruppking
Black Widow Motorsports now has brake cables for all Arctic Cat minibikes except the very early Scccats with the brake light switch located down on the brake assembly.
