I am in the process of rewiring my Ford 601 Workmaster tractor. I have everything in hand except really good battery cables. I want a cable that has a flat end that is crimped not a copper tube end that is mashed flat and punched for a hole. A factory quality cable in other words. I know...
I hate to start a new thread over something that just have been discussed a zillion times here, but after a few search attempts I didn't find what I was looking for. I've got 2 minis that are in need of brake levers and cables. My Trailjet has plastic levers and crappy cables, and the brakes...
picked up another Alsport 3 wheeler, this one is a rigid frame, probably had a 5hp on it originally with band brakes... Did these come with a Y cable to run to each band brake or was there a splitter (connector) like on a car or trucks E-brake? any info or pics would be appreciated.. This one...
Just got back from picking this up. Only about 30 minutes away and the pics are just in the back of the truck on the way home under gas station lights for now. Has a broken footpeg mount. No footpegs. Cracks in the rear fender. Wrong motor. Missing miscellaneous parts like throttle,brake cables...
Hey, don't know if y'all deal with Honda Z50s at this website, but I have a '78 Z50 ('79 model, the frame says, since the bike came off the line in 9/78) with what seems to be a 72cc Lifan motor dropped onto the frame, and I'm trying to square away the cluster that consists of cables, casings...
I need a set of brake cables for the 70' Roadster. Front and rear. The cables don't have to be new but they need to be nice and in good working condition. Also I may be able to get a set made, but need the exact lenghts.
Thanks,
Tim
I was messing around with cutting my throttle cable with regular dykes. Most of the time you will fray the ends when cutting with regular dykes and that makes it difficult to run the cable thru an end or stop.
***Trick: wrap the area you are going to cut with electrical tape 3 times. Cut right...
I see alot of posts about folks looking for cables. I just go to Walmart or a store like that and buy a set of cables for a bicycle bell has a set for about 5 bucks and you can trimm them to fit what you need.
Trying to finish great little bike. need proper seat-have tank. Handle grips, foot grips,front and back wheel, kidney.with brekes as well as all cables! tHANKS FOR YOUR HELP!
looking for front and rear n.o.s. factory brake cables for the 1971 artic cat climber, also looking for n.o.s. gas cap/gauge that says artic in it.:shrug:names or emails of some one who might have this would help a great deal with the resoration project.:scooter:
NOS 'Superior' brand brake levers and cables...
Fits 7/8" handlebars...
Cables are 67" long w/ a 63" long housing, and have a cast lead end piece that is made for these levers, so they fit perfectly...
Four levers/cables available...$14 each (one lever/one cable) plus 5.65...
$18 to you via UPS...........these are good quality.(That's for ALL of them).
I used to own a M/C shop for 15yrs,these were used a lot.
Think they were from Dixie Intl. or Flanders.
3/8 barrel end and nothing on the other end.
regards,Joel
I need a brake cable. I seem to need one that has a rod on the wheel side of the cable that goes through the brake pin shaft and can be turned by hand. It has a hand turn nut on the the threaded rod. I can't seem to identify what i need including BMI and some other sites. Can you link me to what...
