I just posted some pics of flojets on a 'briggs flathead carb' thread. The pulsa jet looks like your vacujet, both are mounted on top of the fuel tank. The pulsajet has a built in fuel pump diaphram and a small reservoir right under the carb so it isn't pulling gas from the bottom of the tank. The pump keeps the reservoir filled which prevents the 'lean' condition from happening when the tank gets low. The pulsa jet only has one adjustment screw. You can set it so you have good power, but it won't idle good. Or you can set it to idle good but it won't have good power. The flojet is more adjustable with both idle and high speed adjustments. The flojet is a float type carb and uses a remote tank which is mounted to the front of the engine or the frame of the bike.
