Hey, new to this forum.
My son asked me to remove the governor on his Coleman CT200u mini bike. After some Youtube videos, I was able to get it out and get the bike back together. I also installed a new carburetor, the one they use on dirtbike. A new upgraded flywheel and 18lb valve springs are on the way. The issue is that when my son or I rides the bike at full throttle and let go of the throttle, the bike backfires blue fames out of the exhaust. The flames can be pretty big in size and I’m not sure what is causing this. I watched another Youtube video on how to adjust the air fuel mixture screw, yet even if I tighten or loosen the screw, the result is the same. Also, the bike is only topping out at around 37 mph with the new carburetor and torque converter, when it used to reach 40 mph with the stock carburetor. Could this be due to the cam timing off (I think I may have reinstalled it a gear or two off) or valve lash. Any help would be greatly appreciated.
- Brandon
- Brandon
