Let me explain further:
I'm building a custom bike, using the Warrior rear hub for a rear wheel, lets just consider that this is the only remaining part from a baja warrior. I can't seem to get enough throw on the lever of the drum brake with the way I have things set up to activate the brake properly, hence I'm looking to get hydraulic disc brakes to work on the rear.
I've done plenty of searching, this is the only thread where someone has put an aftermarket hub on the rear wheel to bolt on a rotor. I'm interested if that works well before I buy the parts and try myself.
