I have a mild blue clone I have done a decent amount of work to. On the most recent build (this week) I file fit the rings and clocked them correctly and installed them into a honed cylinder with good crosshatch. After assembly the motor was run and allowed to reach full operation temperature. I then rode the bike under decent throttle openings to load the rings. I did not have excessive rpm or heat involved in these runs. Progressively the engine would smoke worse only under throttle application. The head and head gasket were both brand new so I believe the oil is coming from the bottom end. My thinking is that I have too much crankcase pressure and this is causing the blowby. I am curious if this sounds like a reasonable problem and if I should try to vent the crankcase. Any help is greatly appreciated.
