I put am putting together an ARCO with a blue greyhound 6.5. I can not get it to idle down to where the clutch is not engaging slightly. It is a Max-torque Clutch. If left on the kick stand it will creep away from you.
So far I have attempted to run the engine without the twist throttle attached, loosened the nut that holds the throttle lever on the engine, checked the rod and governor spring, checked for vacuum leaks, swapped the air filter with a new one, adjusted the little plastic idle screw out all the way, moved the governor spring over a hole on the arm, tightened the clutch allen set screw and replaced the woodruff key, I am grasping at straws.
What am I missing here??? :shrug: Idle jet dirty?
