Bonanza Before and After pictures but need some help...
Ok, first I am sorry to all of you that did not want me to put this engine on this bike.
I promise, no Bonanza was damaged or hurt in order to fit this engine in there. I used the existing holes that were in the bike when I purchased it. Check out the pictures.
So, quickly not probably mentioning everything, sanded to metal, self etch primered, metalcast ground coat, metal cast blue, sanded rear springs gloss coated, refinished wheels, had seat professionally redone, new tires, tubes throttle brake pads, lots more. Was really fun to do.
I was so excited when I got this thing done but then on the first run I didn't go anywhere. Glad I was by myself because to everyone else it would have been really funny.. ok lets get to my problems now.
This is what I did to the engine.. I took out the gov, installed straight pipe, air filter, adapter and drilled out the main jet. probably should have ran it before I drilled out the jet but didn't oh well.
Intalled new 1" bore Hillard extreme duty clutch 41 chain 17t
Problems having.. First I'm barely moving. The shafts are fine and are not slipping. Second at 3/4 throttle the engine starts to stall out. The choke can not be closed the entire way without it stalling out.
So it is a brand new clutch. Is it the gear ratio? 17T aligned with 19 or 20 first jack shaft sprocket.. small, big, small, big to rear sprocket? I guess I didnt do that right..? So I'm going to switch to 10t.
Does anyone know if you can switch out the drive sprocket from 17t to 10t on this model clutch?
Thank you for any help you can provide...
