Brake cable length for Bonanza?
Does someone know the length of brake cable needed for a Bonanza MX1410 minibike frame? GoPowerSports has a considerable amount of lengths to choose from. My estimate is north of 50" but would like to get it dialed in if I can. Appreciate any feedback.
Do you own a tape measure? Try running a string or a wire from your brake to your lever. Use wire ties to mount it where you want your cable. Cut the string or wire where you think you need the ends of your cable.
Now, cut all the wire ties and measure the string or wire.
Thank you for this tip. I like it. As a novice, trying to eliminating the potential of having to cut cable, etc. for good fit. Thank very much.
