Put a 5hp back together. ARC billet rod, new rings, shaved the brows and cleaned up the porting. Valves are lapped in. Running a Briggs downdraft carb. Governor is removed. Going to order a ARC flywheel this week. When I run the bike towards the end of its revving limits, I let off the gas I get a rumble, gargle, backfire? I assume the valves are floating?? I am running stock valve springs.
What is the right fix for this or is this the norm? If heavier valve spring are the answer, what weight??
Any help is appreciated.
