I picked up an older 5hp Briggs. The governor seems to be bypassed ( just the metal rod coming out of the block with a lever on it) It was on a go kart with a direct throttle cable connection to the carb. I'm trying to get this thing running right. It has one of those "easy start" plugs in it thats all gunked up. What is the correct plug for this engine? Do I have to mess with the governor at all if its no being used?
The model # on the engine is 130232
The code on it is 78100407
