I have an older Briggs 5hp flathead in my mini bike. I recently put a new vm20 carb kit from ec carbs on it. The engine will start and idle great. But once I start riding and open the throttle all the way the engine sputters as if it’s not getting enough gas. Then every once in awhile if I roll into the throttle gently the engine will run smoothly but still doesn’t feel like I’ve got full speed. I’ve tried adjusting the carb over and over to no avail. I had this same problem with the pulsa jet carb before I swaped to the vm20. I’m running points right now and have ordered a new pointless ignition from OldMiniBikes Warehouse. But I don’t really think it’s going to fix the issue. The gas tank vent seems fine and the air gap is set to .012. If any one has any advice I’d greatly appreciate it. Thanks!!
