I need a 3/4" shaft crank for a briggs 5hp
bandit 40 Active Member Apr 5, 2011 #2 Apr 5, 2011 #2 nash1970 said: I need a 3/4" shaft crank for a briggs 5hp Click to expand... I have a new style crank:smile:
nash1970 New Member Apr 5, 2011 #3 Apr 5, 2011 #3 I'm hope to get one that will fit my 135212 :thumbsup:
bandit 40 Active Member Apr 5, 2011 #4 Apr 5, 2011 #4 nash1970 said: I'm hope to get one that will fit my 135212 :thumbsup: Click to expand... Is it the short crank that needs the starter cup under your flywheel?
bandit 40 Active Member Apr 6, 2011 #6 Apr 6, 2011 #6 nash1970 said: I don't think it is Click to expand... Well then you got the old style briggs, but you can use the new style if you change shrouds to the newer style
nash1970 New Member Apr 6, 2011 #7 Apr 6, 2011 #7 I saw the pictures of your crank it looks like what I need I'm at work now can I put dibbs on it till Thursday at the latest .
bandit 40 Active Member Apr 6, 2011 #8 Apr 6, 2011 #8 nash1970 said: I saw the pictures of your crank it looks like what I need I'm at work now can I put dibbs on it till Thursday at the latest . Click to expand... You mean this one?http://www.oldminibikes.com/forum/mini-bikes-parts-wanted/45281-briggs-i-c-5hp-crank.html
blkscorpion80 Active Member Apr 6, 2011 #10 Apr 6, 2011 #10 nash1970 said: Yup thats the one Click to expand... That one is in my garage . I have one that was turned down to a 5/8" shaft , if your interested.
Ibanez616 Member Apr 6, 2011 #11 Apr 6, 2011 #11 If you pass on the others i have 2 3/4 tapped and keyed cranks.
