Yup, sounds right to me.... The ratchet system is just ball bearings rolling around in a cup... When the engine is not running.. Gravity lets the ball LOCK up the center shaft and the outer hub.. When the engine is running, centerfugal force throws the ball bearing to the OUTSIDE of the cup and they are safely out of the way.. What you need to do is take your cover off, take the 1/4 inch screws out that holds the screen and ratchet cover out, then pop that cover off from your ratchet thing... NOW you can see the ball bearings OR they fell out on the floor.... What you need to do is clean EVERYTHING up real good.. I use like a flat screwdriver or something to pick out any debris and greese and goop that is in the cup, I use a rag to rub the bearings all off clean and shiny... The center shaft thing will pull right off if the cover is off... Take THAT thing off clean IT all up... ALSO clean the crank shaft up with a rag or something.... THEN once everything is good and clean....
I use a bushing lube but transmission fluid works good too..
Dab a little on your crank shaft and a little dab INSIDE that square ratchet shaft.... put it on the crank again and spin it around a few times to make sure it's spinning freely, Tip your motor to the side away from you a little... Then you drop one ball bearing back in per hole where they ride... Once all THAT is done, lube up the rubber gasket that seals the cover and square shaft... I like to just wipe a little (tranny fluid or whatever you are using) around the inside of that plastic rubber gasket thing, then push the cover back on... YOU ALWAYS want to make sure the cover is on square and it spins EASILY... if it is all together right that center piece should spin pretty easily.. If the cover is bent, or not on strait, it will bind up and the ratchet thing won't free spin very well... But once you have it all cleaned up, the center shaft lubed against the crank shaft of the engine, and the rubber gasket in the cover, it all works well, put the bolts all back together and you should be good..
:thumbsup: OH AND ALSO put all of your shroud bolts in but not TIGHT... then try pulling the rope out a little and watch it recoil back in... Make SURE you get the shroud bolted down right because if IT is not strait, IT will bind up your little ratchet thing TOO and it won't recoil very well... maybe even make a screaching squeeling noise when it's running...
:doah: But basically what your problem is, is those ball bearings in there sticking to the cup they ride in VIA dirt and rust and greese deposits, and it needs to be cleaned... I should write a "How Too" about this huh? :lol: HEY HENT!!! Thats what you should call one of those pic catagorys... (Step By Step How To's)
