I need help on how to fix a broken bolt and striped threads on my crankcase on the briggs 5hp raptor. The biggest problem is that it is not sealed and oil comes out through the hole for the bolt. The threads are all striped on the side cover, but im pretty sure there is still good threads in the actual block. Another issue is that the bolt didn't just virbrate loose from the RPMs of the engine, the bolt broke, and half of the bolt is still stuck in the block!
My question to everyone, is how do i go about fixing this issue??? Is there a known way to get the bolt out without paying somebody at a machine shop to use an ez-out or something? And, once the broken end is out, how to i seal the crankcase, if the threads are striped, and i cant put a bolt in there?
:shrug:
HELP PLEASE!!
:shrug:
HELP PLEASE!!
