Anyone out there have a good technique for putting on those cable clamps without scratching the paint? I was wrapping some clear tape on the frame first . Joe
Mylar strips from file folder tabs. That was an old kustomkartkid trick he posted a few years ago. Personally Joe, I just slap them on over paint. If it's cured, it doesn't damage the paint.
I don't know what type of clamps are being used but the Gilson clamps are plastic-dipped on the ends. Like Dave said, if the paint is cured, there should be no pain. I've R&R'd several times and no damage on any of my bikes...
I just went thru this on my MTD , I spread them open a tad bit first with 2 pairs of pliers , made them much easier to pop on and they didn't loose any spring tension at all !
The clear 3M door edge trim tape you can buy at Autozone would probably be a good idea as well but I found the tension to open those little peckers up was pretty astounding :laugh:
