This is my first post here so forgive me if I miss something. My question is... I built my first Predator 212 last year and was buying parts as I was learning and possibly got ahead of myself on the carb. I picked up a 28mm Mikuni type knockoff D slide for pretty cheap but its actually working pretty well but I can't help but wonder if I'm not gaining something I could have with a more proper sized carb (vm22, 24 etc.) considering my small stock sized valves. I have the AFR around what I think is perfect running mid 14s at a fast cruise and richer at heavier throttle around 12-13 (running a wideband o2 system from Rolling Wrench). I feel that scientifically if my AFR is proper then economy and higher rpm performance shouldn't change with a smaller carb because I'd be running the same air and fuel at the same volume because I'd be limited by my head and valves but I can't help but wonder if I'd be better off on the low end acceleration etc. with a more "proper" sized carb. I'm not looking for reasons to spend more money at this point either so if I'm fine with what I have then I'll leave it be for the time being. For what it's worth the engine doesn't bog if floored while rolling and warmed up, I can't really floor it from a stop because it'd wheelie too hard.
This build is a 3rd gen Predator non-hemi 212 with ported original heads (head measured 21cc), port matched intake and exhaust, staged short header with RVL 4104 muffler, billet +40 rod, hemi style -20 flat top piston around .005 in the hole, .02 head gasket, PVL flywheel at 32 deg timing, Black Mamba Jr. cam, chromoly pushrods, Champion rockers with #26 springs and obviously a gov delete. Compression should be around 10.23.
The engine is on a Baja mb200 with a Tav2, Juggernaut driver with 5:1 on the gears and 19x7-8 tires.
