Could a defective CDI coil pack cause a lack of higher RPM's but other wise run fine at idle and slower RPM's?
Something is not quite right with my Lawn Boy Duraforce 2 cycle engine that I have adapted for use on my Sprocket mini bike.
The CDI coil pack high tension lead was pinched and I repaired it with heat shrink. I had no spark when I started this build and then one day I was spinning the engine by hand and all of a sudden I had spark. I have my suspicions here.
