Hello all,
Decided to open up the cylinder head to check for any issues since during this seasons start up noticed putting the choke / enrichment circuit off the engine would die. I figure it’s a lean condition caused from a vacuum leak at the intake manifold.
I open the cylinder head up, and notice the champion rockers are cracked by the intake valve base / shaft. What could cause this? I was running 60 lb dual springs going down to 37 lb singles now. My thought were too much spring pressure or pushrod gemotry (push rods bit long due to milling of head .065” possiblity? Also put up a picture of the retainers showing that the rocker arm was not centered. The champion rockers were hitting on the bottom side of the retainer
I got a new cylinder head on the way, red RTV sealant (to use around the outside of gasketed areas / on bolts) , and a new intake manifold as well.
Are there any other common areas for vacuum leaks? My engine works strong with choke on, but once I turn it off it dies (I went through the carb 24mm pwk 140 main 32 pilot needle in needle 2 1/2 turns on adjustment screw) could there be a leak somewhere at the carb gaskets? The carb was cleaned before start up. Appreciate anyone’s insight this is the final stretch, and need to get this thing air tight!!!
