I recently purchased a nice used 2020 200U-EX, has stage 1 upgrade. Owner gave me a really good deal, because he said the engine was a dog from the start and did not see much improvement at all with the stage 1. I did some carb adjusting, throttle screw etc.. it still was slow off the line and would pop at higher rpm's. Found out why, the valve lashes were way off. Intake was 0 and exhaust was 1. I went ahead and changed the springs to 18lb and set them to .002 intake and .003 exhaust. Big difference but it still lags some and has a bit of pop still at higher rpm. I'm putting a CVT on it tomorrow after my riser plate gets here. But I doubt it's going to still be what I'm looking for. I'm not looking to build a racing machine. But I do need it too have a lot more torque.
I was looking at changing cam, billet fly wheel and rod. Want to change the Crank to a 3/4 shaft. What all is involved in doing that ? Am I just better off getting a 212 and going from there ?
