KKart, Yes I filled to the top of the threads. will take some out!.
There is oil on top of the piston.
do ya think if I take some out and put head back on I can overcome this problem. Could it get past the piston??
Thinking it might be a oil ring problem????
I did take the vaccum off the carb,
New carb wasn't equipped to accept it ran it down at the bottom of the engine.
Thanks FRANK
oil to the top of the threads is overfull.....should be at the bottom of the threads if it has no dipstick on the end of the plug.....if it's supposed to have a dipstick then you are WAY overfull...I'm not real familiar with the Briggs....
....overfilling will cause all kinds of windage/blowby/oil pumping problems.
