ok first of all i know all of u have some old tenspeeds lyin around the back yard. remove the rear brake cable assembly and lever. be sure to keep the nut/bolt that keeps the tension on the line at the brake caliper the wire runs through.
its easier to install with gastank removed. not to bad is only three bolts. i also found it easier to take the lever off the engine for assembly too.
run the wire thru the throttle lever hole on the engine, (im assuming u already have a return spring) now u need somethin to keep the sheath in place while the wire slides.
ZIP TIE. ZIP TIES. theres a hole on the lever thats perfect for the zip tiieing the cable sheath end in place. then ziptie the middle of the sheath to the middle of the fan shroud. adjust ur slack an tension an there u go. hope this helps someone. i prefer the lever to the twist throttles imo, though either one will work PICS COMING SOON
