ok i have a stock db30. everything is hooked up correctly, i have good compression, the carb is set to initial factory settings. it will only rev up at have choke but idles fine at full choke when cold and will idle back down correctly when at half choke once warmed up. DONT ANSWER IF YOU DID...
first post :D new member but have been loving minis for about four years :scooter:
but anyways lol just got done removing the governor (waiting for my rod and flywheel in the mail) and would like to know how to hook up the throttle. thanks guys
ok first of all i know all of u have some old tenspeeds lyin around the back yard. remove the rear brake cable assembly and lever. be sure to keep the nut/bolt that keeps the tension on the line at the brake caliper the wire runs through.
its easier to install with gastank removed. not to...
