I just swapped out a new doodlebug with a bad carb (old body style) for a new style db30 that seemed to run great for the first 30 minutes.
Before riding the bike for the first time, I oiled up the clutch bearing per the advice of the mechanic from Northern Tool. The bike ran great for my son for the first 30 minutes (he's 8 yrs old and 65-70 lbs). He then took a break for about an hour, and after cranking and letting the bike warm up (it's about 35 degrees) afterward, the clutch automatically engaged during idle, made a funky noise and the engine cut off. It is almost exactly like the video that was posted over a year ago on this forum here:
Doodlebug clutch problem
Unfortunately, in the thread above, the original poster never responded as to what he did to resolve his problem.
I assumed that it was the clutch because I would crank it, lift the back end, and watch the tire start spinning quickly when it made the funky noise. I called Northern Tool to explain what happened, and I was told to re-apply oil to the clutch bearing again. I wasn't very hopeful, but I gave it a try. Sure enough, it resolved the issue. Well ... for awhile at least. He rode it around for another 30 minutes, then let it sit for an hour or so. Same thing happened when starting it up again after this.
So, my question is whether I should keep lubing the clutch bearing this often, or if I should try anything else. Any suggestions?
