It appears your idle is set too high causing the clutch to engage.
- Back out the idle screw a half turn on the carb and see if your rpms drop. The black lever on the carb that controls the butterfly should be able to touch the idle screw. If its not touching then there is a problem with the throttle linkages keeping the butterfly open and increasing your idle speed. If it is touching the idle screw just back the screw out a little and your idle rpms should drop.
Stock engine CT200u EX's should be set to idle around 1750 rpm, +/- 150 rpms. If you are 500 rpms above that it will start to lock up.
