I have an hs40 engine that is non ball bearing on the pto side. I have a ball bearing crank and side cover from another engine. Is that all I need to change it over during a rebuild?
I did that with 2 H35 engines i had. I took a ball bearing crank and side cover out of a low compression rupp engine and put it in a engine that was not a ball bearing with a 5/8 inch output shaft. It worked fine - engine runs great.
