Cu In to HP conversion
it doesnt really work that way. too many other variables. cubic inches is only partly to blame for your horsepower. compression ratio, valvetrain, intake/exhaust.
C9H13NO3
With Briggs and stratton the Ci In is stamped on the head and can tell you what HP your engine was when stock.
Should clarify the original question>>>>>
all of the Briggs serial number tables that I found showed that the 6 in the serial number indicated that it was a 6 cubic inch engine.
I would assume that it is a 2hp?
and a 8 in the serial number would be a 8 cubic inch therefore a 3 hp???
C9H13NO3
It's either a 2hp or a 2 1/2. (I think)
minidragbike
Supporting Speed Nut!
Briggs used engine and carb size for the HP ratings
Some of the same size engine had different carbs so they had different factory HP readings.
