custom Briggs & Stratton 3hp ready to run
True 3hp engine, Block was stripped and polished, shrouds were painted with dupont Base/clear "silver effect", waterslide decaling, engine was rebuilt, Honed, new piston and rings, seals, gaskets tank was an NOS one so its squeaky clean inside, ports were cleaned up, compression release bump shaved off the cam, no gov. Clean carb with all new parts, velocity stack does have a washable air cleaner assy inside to keep the dirt out. Chrome exhaust actually hides a stock new hot dog muff inside so its no annoyingly loud. Has about an 1-2 hours run time on it if that and runs strong. It is a 1980 and I did use a magnetron ignition (no points), 5/8" shaft. Clutch, or the bike its shown on NOT included!!!
I am in the middle of putting 2 more of these together, basically the same, one with an early finned shroud and another like this. that is the only reason I am getting rid of it. $200 shipped
sorry sound is bouncing off the walls in my little shop so it does not sound that great!
https://youtu.be/Nwive3Jy38M
