inside
  1. M
    Nitrous people please step inside.
    Been spraying a dry shot on my 212 for a little bit and it LOVES it... Wanted to look into a wet kit but wanted to see what other people were doing for fuel pumps, how long batteries last on a pump and 2 solenoids etc. Right now I have it jetted up super FAT and spraying it with a .016 pill...
  2. S
    briggs 5hp governor linkage removal inside the case
    I have a old school 5 hp with the linkage arm rod going into the block do i need to remove the side case and remove the nylon gear off the cam and plug the hole or just leave it in with the outside arm off?.and run it....thanks
  3. minikenny
    Must be an inside joke?
    I don't get it. :out: Mini drag bike
  4. S
    My "Perfect" 212cc Motovox Minibike (Video Inside)
    What started as a 79cc kids mini bike from Kmart to goof around on has become a full on rocket project. I added a 212cc Predator, new front hydraulic suspension, new throttle tube, New sprocket adapter for go-kart split sprockets (running a 53 tooth now), off road rear tire, and a hydraulic rear...
  5. J
    A few questions inside ;)
    Okay so i quickly found out that i have a Cat 400x that i bought pretty recently. Im a car guy that love anything fast so the 212cc predator it had was nice but i wanted more of course lol. So i bought a tav torque a-verter from go power sports. Had to modify the frame and everything and long...
  6. JohnnyTillotson
    Bumblebee Sprayin' Tecumseh looking fantastic on the inside
    Broke down the red '68 bee sprayer Tecumseh today and boy does it look good inside. I was told it was used once and put away never to be used again. He was not lying! The inside of this thing is so sweet! The cross hatch pattern clearly visable too. It has a riveted pull cord housing...
  7. P
    bonanza rear shock struts (inside part)
    need just the inside strut, had my covers replated, and I see OldMiniBikes has springs
  8. bikebudy
    TEC Tin Fuel Tank
    Tank Only, off of 3hp side popper Dent Free, Like New inside. Comes with, Bracket, Petcock & Cap. Clean, Paint and use.....50.00 Plus shipping I'll get a better pic of the inside of the tank.
  9. gammatg
    Gas tank for my 69 Rupp Roadster
    Looking to buy a gas tank for my 69 Roadster. Tank can be pitted or dinged as long as its clean on the inside. Please pm me if you can help. Thanks! Eric
  10. markus
    custom Briggs & Stratton 3hp ready to run
    True 3hp engine, Block was stripped and polished, shrouds were painted with dupont Base/clear "silver effect", waterslide decaling, engine was rebuilt, Honed, new piston and rings, seals, gaskets tank was an NOS one so its squeaky clean inside, ports were cleaned up, compression release bump...
  11. T
    looking for a gas tank for a 1969 Broncco TX2
    My son just came across a 69 TX2 in pretty good shape but it has a few flaws...we put a new starter pull on it and she runs fine...till the prime burns off... then on further inspection we could see the tank rusting from the inside out...pulled tank and dump a ton of rusty sludge out of it so...
  12. Scumbag
    RUPP TURBINE WHEELS with Tires, Tubes, Sprocket, Hardware...
    RUPP TURBINE WHEELS with Tires, Tubes, Sprocket, Hardware… front wheel Unpainted, chrome great, with vintage 4.00x6 Carlisle … sometimes a 4.00x6 fit where a 4.50x6 doesn't (Continental 250 forks) REAR WHEEL also in great shape (painted, with stainless hardware...
  13. I
    tecumseh pull.start
    I.have a newer model fun sport tecumseh engine it is missing the fingers Inside the shroud how hard is it to.put them.back in I know there is a certain way they go in just dontknow how any.help.Thanks.:out:
  14. capguncowboy
    So, want to take a stab at it?
    I recently bought a bike. It came today in the mail and this part was inside. I'm not sure what it is, but I'm nearly certain it's not a mini bike part. It's about 22" long from end to end, the straight pipe is about 19-1/4" long and is 1" OD. The end with a fitting is 2" OD and 1-3/4" ID...
  15. Jamie1972
    Tecumseh hs40 blower housings/side tant
    Orig. Hs40 side cover with side tank..long neck. Don't know origin of the cover/tank. Clean inside tank. 45.00 +15.00 shipping.
  16. Steve Albright
    WTB: Muskin Tri Cat rear wheels
    I'm hoping someone out there has a pair of TriCat 5 lug rear wheels. Mine are pretty rusted on the inside also the correct belt or # for the Horstman converter. The engine is a Kohler 5 hp. Steve Albright
  17. S
    Ceramic coated exhaust
    just got my pipes back from the coater and got the engine assembled. Cost me $70 for both coated with ceramachrome 1200* thermal coating inside and out.
  18. gumpit
    Question on making a fiberglass gas tank
    I am wondering on the best way to make a tank that sits on top of the frame like a Heald Super Bronc. I was going to cover the frame with plastic then use "stuff it" expanding foam insulation to make a mold that can be trimmed down. Then make a seperate top half and fiberglass together. Then...
  19. bikerboybenny8
    governor removal questions on predator 212
    I got a hemi head predator 212 at HF last week, since then ive taken apart the governor assembly, removed the black arm that hangs inside the engine block but left the little cog inside.. do i have to remove this cog, or can it stay?
  20. Peekster
    Unknown tank
    Unknown tank Looks pretty clean inside. $20 + shipping
