6.5 horsepower block with - these modifications done by an official small engines experiment
"Killer engine built by 125CCRAZY"308 cam
new honda flat top piston
file fit rings
arc flywheel
8mm plug wire
champion rockers
chr push rods
raceseng guide plate
new intake
26mm mikuni
28.5mm int 25mm exh valves
head milled approx .030
.010 head gasket
grade 8 head bolts
walbro fuel pump
E3 sparkplug
add these items up + countless extras
file fit rings
arc flywheel
8mm plug wire
champion rockers
chr push rods
new intake
26mm mikuni
.010 head gasket
grade 8 head bolts
walbro fuel pump
E3 sparkplug
If your looking for something that will last and you will have a blast on look no longer! I weight 225 lbs and if I'm not careful on the throttle the mini bike will try to shoot up from under me. This motorcycle has a power to weight ratio that is extremely low. The Hydraulic brakes in front and the back work extremely well was my priority. I have a full size BRAND NEW NEVER WORN helmet. I can conclude in this sale as well as a FRESH BRAND NEW SLICK for the back of the fire as well as a double hydraulic rear brake that just hasn't been installed yet. Got no time for this hobby for the time being; I have other bills that I need to pay.
