Yesterday I took the front forks off my one DB30, and found a few things which were not correct.
- Conical washers are missing. Looked on-line at Fastenal's web site, and part number which IPDDave gave is correct and listed, only problem I had is that it noted that all area Fastenal stores did not have this item in-stock, but they said it was available on-line. My local Fastenal store is not open on Saturday so I will check on Monday to see if they can order these items. I did try to order on-line, but could not figure out how to register, or seemed that if was only for wholesale business? Hopefully the local stores can order.
- Pep Boys assembled the front forks incorrectly - had the wheel hub spacers on backward (the short piece is suppose to be on the left side). Not sure if this makes any difference, but reinstalled it correctly.
- Also found that there was not a large washer on the front wheel assembly in front of the caster nut. Went to the local hardware and purchased a washer for .15.
Really makes me wonder if they even looked at the installation instructions when they first assembled at Pep Boys?
