Are you using a drill press?
Cobalt bits can go through some pretty hard steel when mounted in a drill press set to a low RPM and a coolant like RapidTap is used...
Handheld drills usually burn up bits because the RPM's are too high, the drill isn't steady enough to provide a constant bite angle, and the bit overheats and dulls the cutting edge...
