Driven Spring Question
Hello,
I see different colored driven springs listed, but they don’t have good descriptions like the driver springs have.
I am looking for a later overdrive, but still want it to get into overdrive.
Comet has yellow listed as a 30 series torsion spring, but also lists a gold compression spring?
Have seen green, yellow, black etc springs available but the driven on my Chinese TAV is red,
Not sure how that compares to any of the other colors?
I finally have the driver squared away, trying to figure out the driven and it seems there is a lot less info out there about the driven springs.
Can anyone put me in the right direction on this? Any help is greatly appreciated!
Thank you for posting, but I am looking at that same piece of paper with all of the same info on it.
Notice how much info there is for the driver springs, but there’s not much info on the driven springs.
Can the gold spring be added to the yellow spring?
Is the yellow spring the only driven torsion spring that Comet makes?
OldMiniBikes warehouse lists the yellow, in addition to green.
By searching I think I just found out that green is stock driven and yellow is stiffer driven. That’s a start.
Also it looks like the gold compression spring is used for bi-directional use. In other words the gold spring can be used on both inboard and outboard applications. So it doesn’t twist it just compresses. Cool idea
Notice the green stock spring is not even listed? So weird
Thank you, I think i’ll order the yellow spring then.
Also does anyone have a good picture of which of the 3 holes is which?
I think once I get the driver figured out, this bike will be really fun to ride at all speeds.
GustoGuy
The stiffer spring in the driven pulley will make the secondary shift faster to a lower gear (downshift) meaning the belt will travel to the top of the secondary much faster than if a softer spring was in there. The 3 holes allows for fine adjustment when using the original stock spring or aftermarket springs to change the downshift. Too stiff a spring will mean nearly instantaneous downshift when backing off the throttle which will make the bike more punchy feeling to ride whereas if a softer spring was in there it would not downshift as quickly and feel smoother on acceleration rather than always being in the lowest gear the second you back off the throttle. It would be interesting to see if you could get an aftermarket ramp or helix for these secondary like you can in snowmobiles.
joshua. c.
. It would be interesting to see if you could get an aftermarket ramp or helix for these secondary like you can in snowmobiles.[/QUOTE said:
I had thought about seeing if my dad could help me make one, its a neat idea, a slower up shift without the harsh downshift. It would work best for modified motors because you wouldn't spin a stock engine fast enough to notice a difference. from what I've been told due to the fact that the comet 20 and 30 series clutches are set up to fully shift with an un modified engine, even with a maxed out yellow spring they still shift way to fast for a racing engine to reach its full potential and hold down the rpms. I'm no engineer so the ramp angles would be trial and error. my thought would be a longer shallower ramp would up shift slower
joshua. c.
by the way some problems with the quote system there. I couldn't get my message out of the quote. also my edit time ran out while I was trying to smooth out my message and now I cant fix it.
