I just picked up a Ruttman with a 4HP Tecumseh. I have it running pretty good but there is a bad vibration through out the frame at top rpm. Even in a stationary position with the rear tire off the ground, the vibration starts in the upper rpm and is enough to ring your hands on the handle grips. Should I look for a problem with the Flywheel? I'm assuming this can't be good on the engine.
Thanks
Garrett
Thanks
Garrett
