Looks like I'm starting a new project so I'm parting out the motor I had AGK build for my DB65, here's the specs:
- AGK modified 6.5HP Blue GX200 Clone (Shane did all internal work)
- 1.5hrs total on motor, runs MINT, all neighborhood riding
- 14cc cylinder Head
- 18lb valve springs
- Governor removed
- Billet rod
- Aluminum (Honda) flywheel with 4 degrees advance timing
- 22MM Mikuni carb
- Jets: 12.5 Pilot, 130/135/140 Main
- AGK carb adapter w/pulse fitting
- Fuel pump, single outlet
- UNI foam air filter
- RLV candy cane header, wrapped
- Straight AGK header
- New Honda GX200 gasket set
- New Bosch plug
- New set of indexing washers
- cjtmini aluminum motor mount for DB 6.5 conversions
- Comet Torq-A-Verter TAV2
Cost me ~$900 to get set up, I'm looking to get $650 for everything. Busy at work right now but I will post pics later.
If you have a Doodle Bug, this is a trick setup that will make it haul a**. I worked with Shane to build a rock-solid motor, perfect mix of performance and durability. Everything bolts right up to the DB!
PM me if interested. Not looking to sell off anything separate right now because the whole bike may sell locally. Thanks!
- Governor removed
- Billet rod
- 22MM Mikuni carb
- New Bosch plug
