Farm Hog modifications
It's been a little over a year since Farm Hog made her debut and for about the last 4 or 5 months I've been slowly making mods to her on some ideas I had kicking around in my head.
Added headlights, raised the tank, swapped to a spring loaded chain tensioner, and made an exhaust system. You'll see. :D
The headlights are 2 Nilight 18w pods, 1 spot and 1 flood, powered by a lifepo4 10ah battery with a dual light switch. 5 amp inline fuse.
I was going to mount the battery behind the seat but that was going to be a little tight. Then I was going to mount a battery bag to the front of the handlebars but I didn't find one I that I really liked. That's when I decided to raise the tank (which I had thought about doing already for easier access to the engine), and added a battery mount to the underside.
Hat tip to @Mr. Pink for the pictures he posted of the tensioner he uses in this thread, Tips?, post #14 That is the one I chose. I used a piece of unistrut I had lying around to make the mounting bracket.
Due to the design of my frame, my chain is only a 1/2" from the inside edge of the frame. I made a liitle modification. I took the roller nut off and screwed on a rod coupling then added a thick rubber spacer over the coupling. When the bottom of the chain goes tight on deceleration the spacer hits the frame and keeps the chain from having a lot of slack on top. Seems to be working out okay.
Hat tip to @sparkwizard for his post in the DIY exhaust thread, post #23. That gave me the idea for my set up. I found some inexpensive 3/4" sch 40 black pipe 90's and 45's on ebay, and the perforated tube with packing, the clamps and rubber hangar on amazon. Bought the 18"L x 2 1/4" o.d. exhaust extension from auto parts store. I already had a 3/4" rigid conduit with a threaded coupling on hand. Once I cut the conduit to the lengths I needed, I took the pieces out back and used my propane torch to burn off the galvanized coating. Standing upwind of course.
I welded the header, screwed the briggs hotdog on and tested it on the engine, All good.
In the interest of full disclosure, I freely admit that the way I attatched the homemade resonator to the muffler is somewhat sketchy on my part. The diameter of the hotdog muffler is larger than the 2 1/8 i.d. of the exhaust extension and smaller than the 2 1/4 i.d. of the slip fit end of it. I decided to cut off the slip fit end of the exhaust extension and use a butt clamp. I wrapped the end of the hotdog with a couple of layers of High Temp foil tape and then tightened the heck out of the bolts on the exhaust butt clamp. As I suspected, the vibrations from a short test run was causing the clamp to start slipping off the muffler.
That is when I screwed the clamp to the muffler with 5 8-32 screws. So far, which hasn't been very long, it's still holding together. I suspect it will fail sooner rather than later but for now, I'm going to maintain the status quo.
I have to say, I really like the way it sounds. Lowered the pitch of the hotdog and cut a few decibels to boot.
I needed to change the jetting, so I installed the ruixing carb I had on hand and swapped over to a gx200 airbox. I just prefer a cannister type filter instead of the foam filter. Right now jetting is .018 pilot and .032 main with stock e tube. Very noticeable power increase. More testing to be done. Work in progress.
Almost forgot, I welded a 1/4-20 stud to the header for the support bracket off of the engine.
Rapidrob
Very nice job! It bet it is a blast to ride!
Did you add charging coils to your engine? I assembled a charging system on two of my minis to keep the battery charged. A rectifier from AC to DC, and a small BMS board (Battery Management System) that will charge the Li-Po batteries and protect the battery from over/under charging, as well as run a cell phone charger/GPS/ and power source of 5-12 VDC to keep a video camera running. It was very easy to install and cheap to purchase the parts.
Minimichael
That all sounds very interesting. Have you posted about it? I would think a lot of folks on here would like to know more about your set up. I know I would.
No charging coils. The few times I anticipate using the lights stopped me from doing more than the basic set up.
My muffler mod failed as expected, sooner rather than later. Much sooner. It only lasted about 3 weeks. Might be a while before I get back to the drawing board. I'm 9 miles of busy right now.
Get some expended metal, steel or aluminum, roll it into a tube, wrap it with fiberglass insulation, slide it into your tail pipe, drill a small hole in the bottom install a screw to hold the "glass pack" in.
Of course, you will need to connect the tail pipe to the threaded end again.
DaddyJohn
I’ve taken two hotdog mufflers and welded them together into a longer unit before. You’ll need to do a little slice-and-dice so that they’ll butt together and mess with the internals a little. I think I just punched through the center dividers with a taper punch for better flow. Sound with two is quieter than one.
