To do it right you'll need to put a temporary pointer on the flywheel. But to just set the valves, close to top dead center is fine. Just make sure your on the TDC after the intake valve closes.
Can you take a picture of the valve train when the engine starts getting hard to turn and post it? I need to see whats going on. And are you sure the cam timing is correct?
