I bought an old limited modified briggs, then found some gx390 hondas. The briggs is for sale.
It was a used engine, dyno 110 cam, dual bearing welded block, 4.425 horstman rod, wiseco 2 ring piston. I replaced the rod bearing and rod bolts, has a non adjustable arc billet flywheel. It will come with a new gas Tillotson from competition carburetor. This is a Tillotson clone carb setup by dustin ready to bolt on. Will include a header and recoil. Cylinder head is cut for valve clearance, new double valve springs, billet lifters, new gaskets and seals. It will be ready to start. Just bolt the carb and exhaust on and add oil and gas. $350 plus shipping. I do not have the carb back from Dustin so it will ship when I get it.
