So I am getting ready to build this drift trike that I have been collecting parts for & I don't want to use the BMX bottom frame tube. I want to build a frame tube that comes out perpendicular to the neck tube, sweeps down to the back and sweeps back up parallel to the ground that I can then tie my rear axle frame into. I don't have a tubing bender so I am asking, how do you all bend your tubing when building your own minibikes? I have thought of cutting the tubing (1 1/2" diameter) at 15 degree sections and welding them back together to "make" my bends but don't know how hard that will be to keep everything straight and how hard it will be to the neck tube straight as well.
If you look up a Huffy Slider that is the frame design I am wanting to have mine look similar to.
http://www.huffy.com/images/sliders/bike_Comp.jpg
