Front wheel bearing removal.
How the heck do you pop out the front wheel bearings from a Baha Warrior/Heat? Can't hammer them out from the inside, can't pull them out from the outside. What's the trick???
Get yourself a long rod. Skinny enough to fit in the axel hole in the bearing. I actually use the shaft from the spark plug wrench they give you with a predator engine. Just angel it through the opposite bearing side a tap. They will fall right out.:thumbsup: I guess you could also use a long screw driver.:thumbsup:
Yesiree. Once I got the spacer tube shoved over a bit, a few taps and the bearings came right out. Thanks a ton.
Tomorrow I'll try the local mower shop for new bearings and if I strike out locally I'll place an order with OldMiniBikes.
