Normally a sealant is used only when a mating surface does not use a gasket. That means, when the parts were DESIGNED to not use a gasket, not to use sealant instead of a gasket. When a machine uses a gasket the thickness of the gasket is accounted for in the design, so when you use sealant instead of the correct gasket the tolerances will be off.
