I have a set up like that on my bike the final drive ratio is about 9 to 1. I am using a 6 hp tecumseh the low gear ratio gives it great acceleration and hill climbing power but the top end isn't that great. This works out good for how I use the bike. You can probably gear your bike to around 10 to 1 which will give it a lot of low end power. This will work out well if your riding area is small [like a back yard] where you don't have the room or need for high speed. A torque converter will give you both the low speed power and the gear change for high speed. If you just run on a short track the clutch /jack shaft will work fine. If you gear it too low the bike will just want to wheelie all the time and dump you off the back. I know, mine has dumped me a few times, all it takes is to hit a small bump while accelerating and the bike will stand straight up. all though it is fun to ride down the street and be able to crack the throttle and have it rip the front tire off the ground.
