Here I am trying to get spark from this H60 before I torque the flywheel on. It will be a pain to change it after, so....
New points/condenser from OldMiniBikes.
Timing set as per Tecumseh manual(with the head off, .080" before TDC)
Points gap .020"
I set the flywheel on the crank with key and hand spun it with no spark. Hmm.
Rechecked gap. Rechecked timing. Respun. No spark.
Cleaned points with dollar bill. Respun. No spark.
Flywheel magnets pass screwdriver test.
Took coil off armature and measured resistances.
Primary - 1 ohm.
Secondary - 5.03k ohm.
Want to make sure before spending $50 for a coil...
One other thing, this motor did fire on starting fluid with this coil before I tore it down for rebuild.... Did I mess it up in the cleaning stage? Maybe got water in it rinsing it off?
Points gap .020"
Primary - 1 ohm.
