I am re-assembling my H35. I was not the one who disassembled the engine and while I believe I received all the parts sometimes things get misplaced. So, I am in need of help......again. Once I get past this step I will be much closer to addressing the cosmetics with paint etc.
First, in the picture, do I have all the parts to mount the flywheel? In addition to the flywheel and screen, I have the key, the cup, the large washer and the nut. Am I missing any parts?
Second, when assembling it looks like the shaft is tapered. Will I need to "help" the flywheel snug up by using a rubber mallet or will tightening the nut do the job by itself?
Third. Before doing anything I have tried to spin the nut onto the shaft by hand and have not had success. Should the nut spin easily by hand? The reason I ask is because while the threads on the shaft and the nut look fine, the nut stops turning onto the shaft about half way into the nut........so I can only spin the nut a couple of revolutions by hand before it stops. Is this typical or is something not right? Threads all look good and they are clean.
Fourth. Where does the large washer go?
Any other advise appreciated!! It's my first flywheel!
Thanks
Tom
Thanks
Tom
