Hey Guys:
Switched out a engine on my manco streaker and did a 3.5 briggs. Got everything hooked up and the motor is surging and I cannot seem to get the rear wheel to stop moving as the only adjustable setting on this particular motor is the idle setting screw, which is what I need to adjust. Problem is, they say to let it run and then push back the throttle stop and then adjust the screw. I do that and sure enough the result is great, then I let go and the idle goes up and the rear wheel starts turning and it is wandering again. What am I missing? I am attempting to go clockwise with the screw as well as counterclockwise. It does go down, but then when I release the throttle setting...... it goes right back to surging. Help?
