Thanks all for the good info, the shaft is 1". That is the same size as the Bronc's shaft! I was thinking of cutting the shaft off, I was worried that the extra shaft might rub on the plate for the half shaft! Maybe I could grind it down enough so it won't, like you guys said $50 is not bad for the engine!
